Rear Springs Recommendation
Any recommendations for upgraded rear coil springs that won't affect ride height?
There are multiple OEM rear spring options, I just had the second heaviest installed and it corrected my ride height with about 300lbs added to the back; at the time I ordered (February) the heaviest apparently weren't available (in a warehouse), although I've been told by another member on here that they are now available again.
You can compare what color code you currently have with the chart below and the weight you've added
