Rattle/knocking sound up front
Efatl
Forum Donor
11:23 AM
Atlanta, GA, USA
I just received my IG a week ago today and all was fine until yesterday. Sun/Mon I drove 450 miles with no issues. When I drove it on Tuesday, a strange rattle started and is there every time I drive. It is not constant and seems to be provoked by left hand turns. Yet, it is not during every turn and happens occasionally at other times and does not need to be while accelerating. It seems like it is coming from the lower passenger side behind the center control panel or footwell. I searched the forum and saw a thread about a rattle that was caused by a hose not being attached / not being attached properly and it was the cause of the rattle in that thread. All of my hoses I can see (and the one noted in the photos on that thread) are secured. It is going to the dealer in a week, but wondering if anyone has any thoughts?
  • rattle.mp4
    3.5 MB
Strange one. Is it possible it’s coming from the glove box? Maybe try driving with it open.
It is definitely coming from somewhere in the passenger wheel well or behind the center control panel on passenger side
The heat shields under the car can create noises in the footwells. They come and go at will. It was a nightmare to track down, but after the heat shields were adjusted it went away. But it never seemed to come from the centre console, so it might not be them. All you can do is work your way through the options.
Turns out it was a hose clamp rattling against an AC hose- it was out of position and as I turned, it would move and then rattle
Dealing with the same. Where was the ac house located that you needed to adjust?
