Nice work. I will get a 3/4 rack that covers to the roof transition.Playing around in Photoshop (free online version), shrank the Rhino-Rack and swapped out the wheels......
Can you do one with a full length frontrunner slimline rack over safari windows in Donny gray on 17" alloys pleaseAlso did this one with a slightly longer rack and black wheels. Rims are from Nomad, look like a relatively new company but I like their style (the Convoy also come in an appropriate size). Yes they are probably made in Asia but at 1650kg/3650lb load rating they appear to be solid.
https://www.nomadwheels.com/collections/wheels
Happy to try later today. If you can find a side-on shot of the Slimline rack (is it a Slimline 2?) it would make things a lot easier, every picture I found is on an angle.Can you do one with a full length frontrunner slimline rack over safari windows in Donny gray on 17" alloys please
This is my config ordered.
ThanksHappy to try later today. If you can find a side-on shot of the Slimline rack (is it a Slimline 2?) it would make things a lot easier, every picture I found is on an angle.
I am sure there are experienced Photoshop users (I'm just a hack) who could do it lickety split.
Great work! But be careful what you promise hereHappy to try later today. If you can find a side-on shot of the Slimline rack (is it a Slimline 2?) it would make things a lot easier, every picture I found is on an angle.
Here's my first go, hard to get right with the source lighting in the rack picture. I think you can correct for this in a proper version of Photoshop.Thanks
I really appreciate it
rack looks great, hope we eventually get that. Wheels a bit blingy for me but nice photoshop work.Playing around in Photoshop (free online version), shrank the Rhino-Rack and swapped out the wheels......
Here you go:Great work! But be careful what you promise here
There are 1500 forum members that would like to have a slight modified picture of their configuration!
I for example, urgently need my red Fieldmaster with 17“ alloys and the shortened rack you designed![]()
That looks fantasticHere's my first go, hard to get right with the source lighting in the rack picture. I think you can correct for this in a proper version of Photoshop.
Not with a full roof rack on it surely?
Thanks a lot! I would order it immediately if I haven’t done it before!Here you go:
Hey @Logsplitter that looks pretty much like my config
I don't understand why the mounting bracket on the Rhino rack has to be so huge.Thanks a lot! I would order it immediately if I haven’t done it before!
Sans roof rack, roof closed.I don't understand why the mounting bracket on the Rhino rack has to be so huge.
Here’s mine Shopkeep. An you add an Alucab lifting roof please![]()
NiceSans roof rack, roof closed.
