Parking/Auxiliary Heater Without Jack Relocation
alexandruast
7:24 PM
Romania
I've used the mounting plate from Black Sheep Autoterm mounting kit, with a bit of metal work. The kit won't fit anyway, Ineos made some modifications to the inner arch in the meantime, so minor cutting/trimming both the mounting piece and the vehicle is required. Nothing complicated.
Tools used: files, dremel, step drill bit, rivet nuts plus tool, zinc coating, matching paint(optional).
SCR brain relocated with double adhesive automotive-grade tape.
I'm using an aluminum basket from Bison Gear on top of the plastic trim, the ducting is through the basket, will post some pictures with everything mounted back later today or tomorrow.
