Off Road Screen Option
Eric
6:06 PM
Scotland
When I parked up my Grenadier on Thursday night I checked what the charging rate was and % of the battery charge
Come to use it today, the same screen was there, it was blank for all items, %, voltage, charge rate.
Is this a gremlin, has anyone come across this before.
The vehicle was built with the update software. 1946.
The only thing that happened between Thursday and now, is the man fitted a tracker. I was present when he did it when he connected 2 wires, a live, and an ignition live into the existing wiring loom.
Don't know whether to get him back before I approach the dealer
The question is: how did he connect the two wires?
And why the "ignition live"?
In my opinion it should be a "live", always, with own rechargeable battery.
There is the permanently live, (3rd to earth), ignition live is, if the vehicle is moving (or ignition on) without the driver tag (or in this case a programmed mobile phone, ie mine or the wife's) then an alert is generated ( prevents cloned keys, or screwdrivers
The wires were soldered on "piggy back". That was my first thought he forgot to reconnect the original wire. But I'm sure the two original wires where not cut, but soldered on a scraped wire.
It alarms if the vehicle battery is low or cut.
Sorted, tracker + ve ( not ignition + ve) removed from piggy back on a live under bonnet feed. Re attached direct onto battery. Intelligent battery sensor info now displayed in off road, electrical sub menu.
