Thanks very much for the help.Excellent. My suggestions:
- add the words off road somewhere in file name;
- CENTRE DIFF: give example of low traction surfaces (eg dirt or gravel roads, but not sealed). Is shifting across left or right? You also talk about moving slowly does that mean 15kph or less - like you listed in another section or 35kph you also mention?;
- Rear and front diff locker: make last sentence bold;
- ESC OFF: move the 3rd line to the last line and make it bold;
- WADING MODE: perhaps number the 3 pre-requisites before you engage wading mode? That would mean some numbers in other areas for consistency if you agree.
"shift across" will be different from region to region it switches from RHD to LHD. Shift laterally, maybe. Left or right will be wrong for different groups, let's keep it simple and consistent.Thanks very much for the help.
I’ll put up another draft once I review any other suggestions I receive.
I'm not sure of the exact speed up to which the centre diff can be locked. Hopefully someone knows.
I think the 3 pre-requisites for Wading Mode could be done in any order.
The Owner's Manual states that the handbrake is required to engage Off-road mode, but mine engages without it.Offroad mode: was not the Hand Brake also Requiered to switch into?
Thanks Michael - sight of a second version would be much appreciatedThanks very much for the help.
Super idea and great suggestions above. CDL can be engaged below 40kph. I’d also suggest mentioning the handbrake for low range, notwithstanding that it’s not in fact essential (I didn’t know this). Regardless this would be easier given the wording of the alert.Excellent. My suggestions:
Perhaps it's region dependent, but mine engage without the handbrake.Offroad and Wading mode both require the handbrake to be set per the literature.
Now please send a copy to Purnell Adventure and ask them to give a laminated copy to new owners. So I get a copy in Janaury.Here's an updated draft. Thanks for all the suggestions.![]()
Thank you.Here's an updated draft. Thanks for all the suggestions.![]()
