Good Morning All,
I am proud to release the first of our 12V solutions: CTEK D250SE Mounting Kit. If your Grenadier came with the factory dual battery system, then your vehicle is equipped with the CTEK Smartpass. The easiest way to integrate an MPPT Solar controller and improved charging capabilities into your existing system, is to use the CTEK D250SE DC/DC Dual Battery Charger. We have made a mounting plate and connectors that will make this integration seamless and easy for you! The kit includes the following parts and features:
FEATURES:
FEATURES:
- Mounting plate that bolts to under the existing factory CTEK Smartpass. The plate has an offset raised platform for the CTEK D250SE so there is not interference for the wiring coming from the D250SE with your Factory seat brackets and hardware. No Modification needed to install this.
- Rubber coated leg base to insure no rattling of the mounting bracket against the floor of your Grenadier
- Pem nuts on the bottom of the bracket for securing the D250SE so you only need one tool to install and no need to mount the D250SE before placing the bracket in the vehicle.
- X2 copper buss bars that connect the D250SE to your Smartpass perfectly
- X1 Ground Cable Harness for connecting the D250SE to your AUX battery (See D250SE instructions for how to wiring based on what battery you have)
- X1 ALUM Mounting Bracket with integrated Pem Nuts for mounting D250SE
- X2 Copper Bussbars for connecting D250SE to smartpass
- X1 Ground Harness included
Ineos Grenadier CTEK D250SE DC/DC Battery Charger Mounting Kit
*4/1/24 - PRE-ORDERS PLACED WILL SHIP IN APPROX 2 WEEKS* GP Factor is proud to release the first of our 12V solutions for the Ineos Grenadier! Introducing the CTEK D250SE DC/DC Dual Battery Charger Mounting Kit for the Ineos Grenadier. If your Grenadier came with the factory dual battery...
gp-factor.com
