Hi,
I went the easy, lazy way of installing an air heater diesel pickup line in the fuel tank without dropping the tank. All good, I managed to make the required 16mm hole in the fuel sender, but when trying to fit the pipe I dropped it into the tank
In the past 16 hours I tried to pick it up using various claw/magnet methods, but unsuccessful. The thing is, I am 300Km away from home, in an underground garage, and I need to leave. I've covered the hole with a wine cork, I assume it's drive-able to the nearest elevator, where I am planning to lift the vehicle and drop the tank.
I have no ideea if the sender unit removal requires special tools or it can be done with regular tools. I've seen some tanks need a special tool to unscrew the safety ring.
Can you, please, give me some suggestions? Photo with the sender unit before drilling, and a picture taken with an endoscope with the pipe in the tank.
Why Ineos did not put an access hatch for the sender unit remains a mystery to me, given the "built for purpose" mantra.
