Modifying Ext2 outlet from right to left front
WhiteBear
1:45 AM
Berlin
I want to change the switched Ext2 outlet from the right side front to the left side front.
Original the Ext3 switch comes with 3 outlets, 1 front left, 2 rear. The front left Ext3 outlet I cannot use, but would like to have at this position the outlet of Ext2. The right front outlet I do not need at all so would not make a new wiring for it and leave it empty.
Any thoughts how to proceed? Is there an easy way by just changing connections at the fuses?
I would suggest that taking off the overhead panel and moving the switches would be the easiest route. It isn't that difficult to get that panel off, plenty of posts on here about how to do it.
I dont want to move switches, but change the electrical outlet from Ext2 on the right to the outlet on the left front. There is one of three outlets of Ext3 at the moment. Therefore I have to interrupt this connection and connect it to Ext2 but leave the 2 rear outlets to Ext3.
I think the outlets are not separately connected to the the overhead panel which would it make easy. As they are fused 3/1 it should be possible to interrupt them at the fuses but actually I only presume it. This is the f.. mess with Ineos not delivering a proper electrical diagram.
