Mixed Success using Fuse tap/add a fuse - on Grenadier
irtmks
11:05 PM
Mesa, AZ, USA
I am working on the fuse center under the drivers passenger seat. I have 4 different brands of Mini (APM/ATM) fuse taps. I have only been able to use the Lumision Model Fusetap - Mini. And that is after some modification. All 4 brands seem to be about 0.020 - 0.030 too thick to fit into the fuse holder. In addition, all but the Lumison have blades that are distorted or too thick as well. Not a crazy show stopper, but after some time I gave up on the other 3 brands (they were not labled, and ordered another Lumison. (I need two for the Blackvue Parking/Dash system Was wondering if others experienced the same
Yep, I probably should have purchased the ones from Blackvue, but alas I did not. I called Blackvue when I read this. They told me that it would kind of be luck of the draw as they get the fuse taps from many different sources.
It sounds like it maybe a tolerance issue, try a reputable brand who tend to get tolerances right, like Littelfuse or Bussmann.
