Milltek exhaust - DIY?
That should not be hard... It is very accessible and not a complicated system...
I’ve ordered the Milltek non-resonated exhaust kit but having a tough time lining up someone to install it.
Has anyone DIY’d it?
My mechanic installed mine with no issues. Your guy just has to be comfortable with cutting your old exhaust off for the patch in.
I installed mine in the driveway. Simple install. I suggest first cutting the factory exhaust longer than you need. Remove the factory and make a final cut after the Milltek is mocked up in place.
We took it to a local mechanic who is reputed for his good exhaust work and as you say it was a simple install. The tips look really sharp and the various sounds are very cool. Still working on the highway drone though.
Try sound deadening the rear cabin floor to start. That should take it down a bit. I just posted what I have been doing in the rear cabin as an example.
I was going t ask if that got rid of 8th gear highway drone... I guess not.
