Magcode Power System by Rosenberger
DCPU
6:51 AM
Anyone familiar with this system?
It looks a nice almost flush system for front outlets, especially off the flying tails in the footwells or even trickle charging main battery?
MagCode®
Rosenberger MagCode® PowerSystem and MagCode® PowerSystemPro ensure safe and reliable magnetic connection to 12V and 24V external power sources. This includes ‘cigarette lighter’ receptacles commonly found on many vehicles such as cars, trucks, vans and campers as well as motorcycles and boats.
Magnets in the PowerPort and PowerClip ensure contact is made between the two parts of the connector as well as providing a switching function. The flat contacts only carry power when the moveable plate in the Port is magnetized by the magnets in the Clip. Totally short-circuit-proof, the MagCode® PowerSystem is designed to avoid other metal objects or permanent magnets inadvertently energizing the contacts.
MagCode® PowerSystemPro features an additional twist lock mechanism for applications where greater separation forces and higher current load are necessary. In addition, the twist lock function guarantees switching will not occur before the outside contact has been closed – therefore eliminating potential arcing problems.
View: https://youtu.be/UR1bRHzuQ18
MagCode®
I use a magcode in my Defender for charging the battery. It’s a brilliant simple solution!
