Looking for the 500A power point
Jeffrey
Forum Donor
2:28 PM
Santa Barbara, California, USA
I'm wiring up my Warn front winch. I hear the 500A (EXT 4) power point is near the front right wheel well. Can't find it. Advice? Thanks.
There’s my thread on what I did
Thanks everyone who advised. Nice of Ineos to make the PowerPoint access easy!
What a PITA to locate and access the threaded stud on the relay. The stud is 10mm in diameter, larger than the hole in the power cable lug from Warn. I didn't have another larger lug and crimper so I carefully drilled the hole larger. The remaining metal on the lug was somewhat less than ideal so I used a flat washer on both sides of the lug when I connected it and used a 10MM flange nut to clamp it well (you need to provide that, thanks again Ineos). I routed the negative cable to a chassis ground point that I identified on one of the long bolts that mounts the starter. I haven't tried it yet to see it that will work.
