Local Forum Guidelines Fr (Lignes directrices pour les forums locaux Fr)
Stu_Barnes
Fixer & General Dogsbody
5:21 PM
Los Angeles
Welcome to the local French speaking forum,
This section of the INEOS forum is for particular conversations concerning the French speaking area. A few examples of what lives here as opposed to elsewhere on the forum.
  • Petrol station prices in a particular town / village.
  • Recommendations on coffee bars, restaurants, pubs in a particular town / village.
  • Conversations about and arranging local meetups.
  • Conversation about local trails and routes. Although if you put together a trail/route report with photos and GPX files etc then please put this report in the Off-road, Overlanding, Green Laning & Equipment section.
Anyone registered on the forum can comment or start a thread, but if it has no particular reference to WA then it will be deleted or moved to the relevant portion of the forum. Technical fixes or conversations more appropriate for the wider global community will be moved accordingly.
You can use your native language for this section of the forum.
The code of conduct applies here as elsewhere on the site, if you need a refresher then please read Forum Guidelines (please read).
Tags, please use at least 2 tags for threads that you start, they auto populate to some degree when you create a thread. This helps to categorize things and in future will be invaluable for cross referencing.
@Largo "WINCH" has volunteered to run and moderate this portion of the forum, please don't waste his time by reckless behavior or attitude, I'm sure that won't happen but I had to say it.
Stu.
Bienvenue sur le forum local francophone,
Cette section du forum INEOS est destinée à des conversations particulières concernant la région francophone. Quelques exemples de ce qui se passe ici plutôt qu'ailleurs sur le forum.
Les prix des stations-service dans une ville ou un village particulier.
Recommandations sur les cafés, restaurants, pubs dans une ville ou un village particulier.
Conversations sur les rencontres locales et leur organisation.
Conversations sur les sentiers et itinéraires locaux. Toutefois, si vous rédigez un rapport sur un sentier ou un itinéraire avec des photos, des fichiers GPX, etc., veuillez le placer dans la section Off-road, Overlanding, Green Laning & Equipment (hors route, en terrain découvert, en terrain vert et en équipement).
Toute personne inscrite sur le forum peut faire des commentaires ou lancer un fil de discussion, mais s'il n'a pas de référence particulière à la WA, il sera supprimé ou déplacé dans la partie appropriée du forum. Les corrections techniques ou les conversations plus appropriées à la communauté mondiale seront déplacées en conséquence.
Vous pouvez utiliser votre langue maternelle dans cette section du forum.
Le code de conduite s'applique ici comme ailleurs sur le site. Si vous avez besoin d'un rappel, lisez les lignes directrices du forum (à lire).
Tags, veuillez utiliser au moins 2 tags pour les fils de discussion que vous commencez, ils se remplissent automatiquement dans une certaine mesure lorsque vous créez un fil de discussion. Cela permet de catégoriser les choses et à l'avenir sera inestimable pour les références croisées.
@Largo "WINCH" s'est porté volontaire pour gérer et modérer cette partie du forum, merci de ne pas lui faire perdre son temps par un comportement ou une attitude imprudente, je suis sûr que cela n'arrivera pas mais je me devais de le dire.
Stu.
