Loadspace retention kit
NorCal Green
8:33 PM
San Francisco, CA, USA
Grenadier's accessories page shows a picture of a loadspace retention kit, though not available as a known accessory through Ineos. A bit of online sleuthing brings up the Land Rover "Loadspace Retention Kit" (known as part VPLWS0243 or like-for-like Jaguar C2Z31984). That non-IG part does not come with rail/track adapters. Question is: If I find the LR adapters, is the loadspace rail in a Land Rover compatible with the Grenadier L-Track?
Ineos' accessories page ("Interior | Inner workings"):
fa14db2a8c6e460e81b9ed54670e3136
The rail adapters ("tie down hook") exist as Land Rover part LR038108 (~$60/each), or Jaguar part C2Z26255 (comes in 4-pack?). These don't look remotely the same as the Ineos picture above. And it's not clear if these would even work with the IG L-track. They are also backordered special parts, not easily tried and returned if they don't work. A reasonable picture of the LR rail can be found on Ebay:
Has anyone had success with this loadspace retention kit and their Grenadier? Or knows when/how/where these tie-down hooks/adapters for the Grenadier will be available?
Thanks
Thanks
It's called the Ineos Cargo Management System. Josh from Automobile Obsession (USA) talks about it in this YT about his recommended accessories for the Grenadier.
Upvote 0
Thanks, though this is a properly kept secret accessory it would appear. Nothing about it on the Grenadier site itself, nor in the configurator. Found it as "Cargo Management System - Code: VFY - MSRP $355.
The Jaguar part above, looking visually identical to VFY but without the adapters, came in at ~$90. Collecting dust since it won't work without the adapters. If anyone happens to have access to a Land Rover with load rail installed it'd be great to get dimensions or a direct fit check. (the local LR dealer said they had none with a load rail installed)
Upvote 0
