Leaking - Multiple Areas
Yes, they go down the A Pillars... Did you pick a Grenadier up?
Nope. Just a lurker trying to figure if I want to get involved in some way.
Intrigued by issues like this and the eventual solution, ie: @Jean Mercier has a leak but the water collects at the Jack. A-pillar is about as far as you can get unless the drain is clogged and it’s finding a path between the headliner and roof.
Well mines in for water leaks again - water in both drivers and passenger footwells. No watermarks on roofliner, no drips down windscreen.
Its had the safari seals replaced and the door seals restuck and notched.
The latest is replacement of the drain tubes and the grommets for them in the roof. Apparently these are a new style grommet.
Waiting to see the outcome. In the meantime I have a quartermaster to drive about in - looking for some big stuff to buy :)
Look forward to hearing what Triad has to say!
Thanks for your input here. Was the leak resolved, and what was the culprit? My Grenadier just showed droplets on the dash under the camera for the first time after 9 months. Bummed for sure...
I had the same issue with the safari windows. The dealership couldn’t fix it the first time, but after replacing the rubber seal, the problem was solved.
Your drips were on the dash like mine? My drips seem like they are coming down from the windshield camera/rearview mirror which seems like good distance from the safari windows.
