ISA Map Update DIY with Fat32 USB Stick
Fischvergiftung
10:53 AM
Eilsleben, Deutschland
Good morning,
does anyone succsessfully updated the ISA-Map with the https://grenadier.mapupdate.info/ file?
I have downlad the MAP file > extract the .zip > copy the folder "dbupdate" on a fat32 usb stick > try to update the Car > always error messages > the files are damaged
I have try 2 different USB Sticks, always the same.
Maybe fat32 format over Mac OS ist the Problem...? Today i´ll try Windows with the same Workaround
Does anyone have a different solution?
Greetz Alex
Ok win far32 file on, plugged in.... Now What?
OK insert USB after you are in Map update screen and it prompts you. What is this anyway? LOL
Hi. Once I plugged in the the usb stick on the port nothing happens. I go to Map Update and the QR code appears but nothing happens. Anyone knows why?
make sure you used a windows computer to format the usb. I had to first navigate to the map update menu, then insert the usb stick for it to recognize there is an update on the stick. Inserting the stick first at the Home Screen the system recognized there was a usb but did not start the update. I was fiddling around when I got it to work so ymmv
