Info “trip”
ORSO
12:17 PM
Italy
Hi, last week I had the service done with the relative software update.
Since then the “trip” information no longer detects the distance traveled since the last reset but only indicates the distance traveled daily and the following day it resets automatically.
Do you have any idea how to make the partial distance visible again as before? In this way it becomes useless for me.
Thaks
Thaks
Isn't there something along those options in the sub menus in the main Settings 🤔 I'm sure I saw something like that, unless I'm thinking of the wife's car. It may well just be the update reset some of the default options
I had saved the file but instead of as a pdf it saved it as a webloc and I can't open it anymore
Yep, I yearn for a proper set of dual trip meters like every other car I've ever owned. What ineos has provided, unless I still aren't using it properly, is next to useless.
You could always use the trip meter in the Pathfinder Roadbook option left running in the background
Thaks
You said you had a recent software update. Here in the US, we are being told that is still being worked on as the current update caused more problems than fixed. So was this update the one to fix the speed and fuel warnings? If so, did it work? Also are you able now to turn off the service warnings too??
If you didn't heard of this manual. You can download it here (tread)
Rok_Dr’s Exceedingly Unofficial Owner’s Manual Supplement​
Can you, or anyone reading this post, please provide a new or better link for this? When I try to click on the links I found on this forum via using the search menu, I keep getting this error message:
I’ve read through this thread and played around in settings - so there’s no “normal” trip counter that records distance until I hit clear?
Don't forget you have also got an additional trip recorder in the pathfinder menu.
I have seen two different Trip Meters when cycling through options (by pushing the button on the end of the turn signal stalk): One that displays distance since “Start” (each day?) and the other is simply distance since Reset.
Cycle through the options to "Trip", then a long press on the button at the end of the turn signal stalk gives you two options: From Start and From Reset.View attachment 7882846
And while displayed a short press toggles between the 2 options and a long press resets the relevant trip meter. (Its all in the manual :))
Steve
