- Local time
- 10:59 PM
- Joined
- Mar 9, 2022
- Messages
- 524
I've only had heated seats with leather. In my mind the cloth doesn't seem as optimal. How well does the heater work?
Hot very good heating in the seats .I've only had heated seats with leather. In my mind the cloth doesn't seem as optimal. How well does the heater work?
Gold.I ordered the heated seat for a dumb reason, it fills out the console panel.
I'm sure you could just unwire the seat switches and hook something else up if you wanted. If I lived somewhere that hot I would do that.Gold.
I ended up with them by default as you can’t delete them when choosing leather seats.
Not a lot of need for heated seats in Queensland Aust for 11 months of the year, although it’s gotten down to around 8-10 deg C here of a morning and everyone is freezing.
I would have preferred the blanks on the console to mount other things.
4.3 degrees at 5 am this morningGold.
Underseat cooling fans?I'm sure you could just unwire the seat switches and hook something else up if you wanted. If I lived somewhere that hot I would do that.
Theoretically this could work... I'm not sure if the output travels through the body control module or if it is like aftermarket heated seat kits (where the switch directly controls the heating elements). If it is direct, then the 3 steps could be translated into 3 fan speeds (assuming it is PWM instead of voltage steps)Underseat cooling fans?
You are looking at it all wrong. On the hottest day, crank up seats and keep a/c low. That way when you exit the car, it will feel like a cool day outside.Gold.
