How to get a cable from the roof into my grenadier
Koenstravel
2:36 PM
België
Hello guys, I want to bring in some cables into my grenadier from the roof ( will be a RTT Alucab) for feeding 12V to my RTT and for potentially bringing solar to connect to my MPPT. For clarity I do have the pre-prepared electricity connects on the roof and plan to use these later for LED lights etc. These pre installed connectors connect to the start battery. I want to use a new cable next to the ones that are pre-prepared so not using an existing one. I will connect this to a separate household battery system ( victron). My ask is now has anyone some best practice where and how you brought in the cable and maybe share some pictures of how you did this.
that would be awesome !
Thanks a million and Happy driving
greetz
K
Hi Koen,
I’ve used one of the pre-prepared holes for 3 cables. 2 for the solar panel and 1 for the 12v outlets in the tent. Just remove the 6 screws and you will find it. If you use a small cable first you can easily guide the cable inside.
And when you have only one cable without protection you can make it much nicer then I did 😂
Here is some info about our Victron setup:
View: https://youtu.be/yPmnRQ1u3RY?si=_5vPb_6gN2iA8zh3
Hi Koen,
You’re a bloody legend. Thank you. I was just starting to plan an install for a cell booster kit. You probably saved me a couple of hours fiddling around.
Are these pre-prepared holes located at both the front and back DTP plug places?
If so where inside the cabin does the front ones come in?
Hi Koen,
Thanks for the golden tip, will explore this over the weekend, save travels.
