Help taking off wheel locks
WanderingSniper
4:35 PM
Los Angeles, CA, USA
My grenadier came with wheel locks. When I told
My dealer I didn’t want them they removed the charge and the locks, but none of us checked the spare as it was hidden behind a plate. In a recent outing I needed it but realized the problem. I can seem to get it off and I’d prefer not to drive to the dealer. Any ideas? The spinning outer sheath really makes it difficult.
Only method I’m aware of is to get an extraction tool/kit. Basically you slip a sleeve that fits your lug nut size over the wheel lock. Said sleeve has a hole in it that allows you to drill into the wheel lock. Once that’s done, an extraction tool bites into the wheel lock via the hole, allowing you to unscrew it with a ratchet.
