Build Thread @Heater Build Plan
4:27 AM
North Texas
Does anyone know - Possibly I overlooked it but will the suspension accept a 2.0 x 3.0 +“ lift and larger tires to accommodate clearing rutted back country areas? Is there anything in-work or existing that can be fitted, such as OME or another Defender or other accepting kit?
Just planning ahead and getting the conversation started.
Thanks.
The suspension set up has more In common with a jeep wrangler or Nissan patrol than an original defender.
I know there are spacer lifts already in the works, and probably coil lifts to follow.
The stock suspension will clear 33s at full flex, so I doubt you'll need 3" of lift to accommodate 35s.
