General Fast. Idle
Andrew Kilby
1:22 AM
Sunshine Coast - Australia
New to this so I hope I am doing the right thing.
Does anyone know if the off road mode or off a winch is fitted there will need a fast idle mode to keep the batteries topped up as best they can?
10:22 AM
[QUOTE username=Andrew Kilby userid=9009180 postid=1332869188]New to this so I hope I am doing the right thing.
Does anyone know if the off road mode or off a winch is fitted there will need a fast idle mode to keep the batteries topped up as best they can?[/QUOTE]
Good question.  I don't know for sure but my guess is that the IG does not have a "PTO" (power take off), and just runs the winch from alternator power.  But like I said I don't now.  Also not sure where you live or if they call it "PTO" where you live.  But in the United States that's what it's called. Since the winches pull so slowly, I think the power is in the mechanical advantage of super low gearing, making such torque not require more energy than the alternator or battery can put out.  It would be cool if the rig automatically revved up if it needed to.  Looking forward to a more sure answer in this thread.
WhiteBear
4:22 PM
Berlin
There is no PTO, where should it be driven from?
It is a Red Winch
Andrew Kilby
1:22 AM
The very old land Rover had a PTO. This was driven directly from the gear box .
The G does not have that not would I expect it to.  The electric winch will draw a lot of current. Ii an Australia but I have heard  in the USA that fast idle is common and used to get the alternator output up or warm up the be engine I'm the very cold.
I want to get the alternator output up so my coffee machine will work. Gotta love the decadence of a coffee machine while over landing.
emax
Forum Moderator
Local Group Moderator
4:22 PM
Coffee is like Diesel: indispensable.
3:22 PM
[QUOTE username=Andrew Kilby userid=9009180 postid=1332869675]The very old land Rover had a PTO. This was driven directly from the gear box .
I want to get the alternator output up so my coffee machine will work. Gotta love the decadence of a coffee machine while over landing.  [/QUOTE]
The inverter is 2K so it will work with the engine off.
10:22 AM
[QUOTE username=CountyV8 userid=8620645 postid=1332869877]
The inverter is 2K so it will work with the engine off.[/QUOTE]
It's 2k? Great! I hadn't read that anywhere, very good to know. You can actually do something with that.
emax
Forum Moderator
4:22 PM
A PTO only works if the engine works. Bit if she doesn't for whichever reason, you're stuck.
If I am not mistaken, the "aux battery" is advertised as a power source for e.g. a winch. If this is so, the winch should work without the engine running. - at least with a second battery.
