Hello all!
Be successfully managed to install the dual battery setup and we got 100ah lithium lipro4 installed with a redarc system. Now the top plug and play electrical outlets are being fed directly from the second battery.
I'm happy to also connect the back outlet directly to the second battery so now both of my fridges are draining the lithium battery. No issues whatsoever!
However right after taking off from a recent road trip in the desert and going on to gravel/road I suddenly faced with a very weird problem. ABS+ESC warning lights are on.
Keep in mind that I have done zero cutting or rewiring of the cables and I made sure to stay on the safe side during the dual battery setup as I didn't want to mess up the warranty. My car was running perfectly without any issues untiltoday!
Was my dual battery setup and this issue related? They just happened right after each other, I just hope its a coincidence!
The dealership did a check and all fuses are good and there is no harness or obstruction anywhere in the wheels. They continued to perform 3-5 hard resets and all of them come back with the same errors. They do clear however just simply driving for less than a minute you hear the doors lock (safety) and the errors show up.
Here is an attachment of the error codes.
Edit1: We checked the ABS system, it seems fine no issue everything is intact.
Edit2: The Head unit is fine also no issues here.
Edit3: The Difflocks are working as well, we replaced the oil while at it:
Edit4: Break pads have been replaced, as the sensor was very close, so might as well change all 4.
Edit5: Every fuse in the car (Main Fuse box + Cockpit fuse box) are OK, nothing burnt!
Edit6: The Difflocks will never engage, you are given the "Check for surrounding conditions" but they will never engage.
What seems to be the problem
