Engine warning light after refueling, is there a permanent fix. It comes on after every refueling
Confirm you are at appropriate tire pressures (36F/R for up to 3 passengers); beyond that, there's nothing a software update would do to change the steeringthank you for that, do you think there will be a software update to correct the way to sensitive steering too?
