Bumpers & protection Diamond/checker plate for rear quarters and below doors
Is anyone producing the plate that runs along side of vehicle (under the doors) and at rear corners of truck yet?
Hi BigJoeJack, I have seen many older Defenders with checker plate at the bottom of the doors and vehicle. From what I have read, many times it is because this area rusted out and it was away to cover it up. I for one think it often looks good and can serve as some protection too. Since the door skins are aluminum, using anodized aluminum diamond plate and aluminum rivets would work and be similar metals would not have galvanic corrosion. You would need to seal the top and side edges to prevent moisture from getting trrapped and allow a portion of the bottom to not be sealed so any trapped water could drain out. DaBBull
Yeah, I was thinking it is good looking plus it could offer a little protection. I wouldn't mind seeing it on back corners, on piece that encompasses taillight, and also include some simple bars over the taillight. Maybe aftermarket will come up with these parts soon enough.
Thanks,
Joe
