Cra-Cra, annoying sound from the rear...
alvan
7:56 AM
Cagliari,Italy
For a while (not from the beginning) I have been hearing a sort of light, metallic cra-cra around the exhaust/rear various protections area. It appears when the gear is a little high compared to the speed and therefore it is certainly a resonance. At first I thought I had solved the problem by tightening the jack well inside its housing, but it reappeared after a while. We inspected underneath and the only suspect seems to be that silver sheet protection which is fixed only towards the center and has two wings free to vibrate. Obviously nothing major but, considering that the Grenadier is very silent even off-road, that cra-cra is irritating and doesn't seem difficult to resolve, once the origin has been identified...
in mine, the heat shield installed behind the rear underbody protection guard was loose. Try to tighten or jam something to prevent shaking.
I can confirm. The heat shield is made of two thin sheets stacked on top of each other. When there is vibration, they vibrate against each other and make these noises.
Remedy: Use pliers to bend the two sheets together at the outer corners and press the fold together firmly.
Blind rivets are a tempting solution, but they are critical because the application of force is too selective and the panels are very likely to crack.
