Connecting a compressor to battery with clips??
Rupert
#4082
6:45 PM
Dallas, Texas, USA
OK, I have a compressor I need to connect to air tires. Are the points in the engine bay the connection point? Asking for a friend....
Yes, You could use the jump points or the cigarette socket depending on your compressor. My emergency/portable compressor uses the cigarette socket.
Yea man, anytime. You should check out the link above. All four tires at once and it is super fast. all 4 tires in about 4 minutes from 20 pounds to 40.
I'll be right over...
Morrflate is a great device. Same concept is sold by many brands and plenty of YouTube vids on how to make your own if you're handy.
I quite like the two-tyre options because I tend to run my front tyres at a different pressure than the rears if I'm loaded heavy or towing. Two-way has less hoses to store and no real time or effort for me to move the chucks one time. You can do split front to rear pressures using a four-way device with a bit of management.
Yessir, I agree on your point. The mohrflat comes with a pretty hadny gadget allowing the differing levels in each tire . I too run dofferent levels in front and rear depending, but you are spot on regarding the hose storage. My daily is a Land Cruiser, and the space in it is a far cry from the voluminous space in the Grenny - so the hose storage is not as big of a deal anymore. Took up half of my large drawer in my LC.
Can safely say I missed that feature in the Morrflate. It's like they already planned for that requirement :unsure: 👏
Check your current draw before plugging into the ciggy socket.
My dual compressor draws 90Amps at startup and 50Amps when in use; I use the engine jump posts and have the engine running.
I installed a NATO connector on my compressor. It works perfectly with the 500A outlet.
