Centre Differential
DCPU
6:58 PM
So there's some stuff posted on the front and rear differentials, but what about the centre differential?
Have Ineos got a bespoke one, third party supplier or rolled along with the ZF one?
The only reference with ZF I've read suggests that they were/are using a unit from Torsen. Do Torsen make anything manually lockable?
Anyone know anything more?
bemax
7:58 PM
Is Torsen a company? I always thought it is a short version of Torque sensitive.
D
Deleted member 9045924
Guest
The center differential is a Tremec two-speed transfer case unit with a 2.5:1 low range.
DCPU
6:58 PM
Is it located at the front of the case?
Checking my photos, all only show the rear of the case.
So is it all so much more compact than a land rover setup.?
Green is the linkage for hi/low; and blue the linkage for the diff lock?
Krabby
Global Grenadier 76
Forum Moderator
1:58 PM
New Jersey, USA
I can’t seem to find the answer so forgive me if I missed it, but what rear gear ratio is in it? The Rubicon Jeeps are 4.11 (can get 4.88 from factory), regular JK 3.73, new Defender 3.55 but I can’t find the specs on the IG.
NVM - I found a thread that said 4.10s.
