Can we walk on our roof?
Chadd7
3:41 AM
NJ, USA
Just wondering if we can climb up there with a folding chair, sit down with a cigar and watch the sunset. I just don’t want to dent the roof.
Jean Mercier
GG#920
9:41 AM
Sint-Martens-Latem, Belgium
It is OK, but place some mattresses around your car ...
That was the day I got my car, I tried it and got a telephone call while on the roof :ROFLMAO:
But I was anyway quite cautious not to damage my roof ;)
Tazzieman
7:41 PM
Tasmania
1. Place a sheet of plywood over the rails
2. Don't hit the booze before or during.
You don't want the "he died doing what he loved" epithet.
It's a long drop to the ground!
FieldMonster
Forum Donor
8:41 AM
United Kingdom
I sat on mine (feet on the spare wheel. Bliss) but I’ve since noticed a small dimple/dent up there that I worry was, perhaps, a result of my bony bum and it’s put me off any return visits.
Am I wrong to be concerned about superficial deformation of the metal on the roof? Was it just a coincidence and not caused by my posterior?
Tazzieman
7:41 PM
Tasmania
The loads are taken by the rubbing strips and the gutters/grab handles if you mount bars or a rack.
The panels are thin, to save weight!
That said, I'm sure someone will put armourplate up there...
FieldMonster
Forum Donor
8:41 AM
United Kingdom
Makes sense. I’ll need to avoid putting weight on the metal skin above the cabin then. Perhaps we will be practicing tightrope walking on the load bearing strips. 😆
I think the chunky bit above the rear door itself (I think if it as the lintel) is pretty sturdy.
Tazzieman
7:41 PM
Tasmania
There is plastic over the steel frame, and elsewhere. Tap it!
Tazzieman
7:41 PM
Tasmania
I will not die, it's a long drop indeed, because I am as light as a feather :ROFLMAO: 🪶
No but you will be in a wheelchair. It is more than the "orthopaedic height" up there ; the "neurosurgical height" is how i would term it.
Chadd7
3:41 AM
NJ, USA
Darn. Was hoping this was not the case.
DenisM
6:41 PM
The issue is "distributed" vs "point" loading. I secured a sheet of 1800mm x 1200mm x 17mm ply on the loading strips. No problem walking within the bounds of the plywood sheet. To sit on the rear section of the roof, put a plank across the load strips and sit on that....
AnD3rew
Inch deep and a mile wide.
7:41 PM
I walk/sit on the roofrack or if necessary the black strips. I don’t put weight on the actual painted surface. I am sure you are in no danger of collapsing the roof, however there is a good chance you might damage or scratch the skin.
Chadd7
3:41 AM
NJ, USA
I don't plan on having a sheet of plywood with me when I drive up into the local mountains and stop at a scenic parking lot. That's the issue I have.
shiv.nandak
3:41 AM
Pittsburgh, PA, USA
Thank you for asking this question! I was wondering this since I need to change a light bulb in my garage. The ladder wouldn't reach but the Grenadier's roof will.
Chadd7
3:41 AM
NJ, USA
Perhaps there is a market for folding chairs that somehow rest on the loading strips so we can climb on without damaging the roof?
Tazzieman
7:41 PM
Tasmania
With optional cigar and bear spray holders ?
Chadd7
3:41 AM
NJ, USA
I just want to sit atop my Gren, smoke a cigar, sip some coffee, and watch nature.
AZGrenadier
Global Grenadier #0031
3:41 AM
both my son and I have been up there at the same time. I am about 180 and he is 160. No dents, just some muddy footprints.
