CAN Gateway failure - Batttery disconnection
nasmo
4:20 PM
Kuwait
Beware! If you ever have the battery disconnected without following the correct procedure. Your abs+esc+ dofflock lights will come on and there is NO WAY to remove them.
You will also be limited to 80KMph speed unless you switch off the engine for ten minutes. The errors will stay remain however.
There isn't a reset that can be done. Dealership has nothing in its hand . It is a known issue and INEOS will replace the CAN gateway if there is no misuse . It can take few months to fix as dealerships don't stock this.
I was the first case in INEOE servicing history with this issue back in December. Now 5 other cars are having the same issue and they are trying to address this .
