Build Thread Battery and Roof Rack New Install
9:13 PM
So today I installed the Front Runner 3/4 Rack and a Kickass slim line lithium battery. I did not opt for dual battery because I wanted to do my own thing . I had to modify the seat slider handle and move a connector but the battery fit under the seat. At some point will be putting in the 40V DC charger for the battery but for now I thought people would like to see the battery. Had to raise the seat up a few clicks but this works for me. The shorter you are the better this would work. It also means I get to keep all the space under the front seat.
Are you Aus based, looks like US? Been waiting to get hands on 3/4 rack. Do you know what your overall height is now with it added? Is it less than 2.1m?
I am US Based. Can Measure for you tomorrow its cold out right now and dark.
Was lso going to fit also. Check out Leitner Design USA also lighter than Rhino.
I am after placing the rack directly onto the roof (on Grenadier rubberised mounts) having fixings similar to Leitner solution that bolt to the main roof members ( existing rails). The roof gutter is actually not as strong being only pressed metal.
This also provides a lower profile and some reports indicate less wind noise.
