Appreciate some help with adding an AUX battery
1:11 AM
Miami Beach, FL, USA
I have been taking the kids camping pretty often and the power station we had wasn’t really cutting it. I decided to upgrade to an EcoFlow Delta 2 which has 1024WH and can run at 1,800W output. I also added the EcoFlow alternator charger which is great because it outputs 800W and charges the Delta 2 in a little over an hour. I thought about going with a regular Lifepo4 battery and a dc to dc charger and then an inverter but I couldn’t find anything that would charge a battery as fast as the alternator charger which only works with EcoFlow power stations. I am not saying that a faster charger doesn’t exist, I just didn’t find one. If something does exist I would love to know.
I got the Delta 2 to fit under the rear passenger side seats by removing the JBL amp which I never used anyway. I would like to expand the capacity of the delta 2 using a lifepo4 battery but everything I am finding online talks about taking a battery and having it charge the power station using xt60i cables. That’s fine, but how do I get the battery charged? I have watched so many YouTube videos and they all say expand capacity, yes you are expanding capacity but how do you get the battery charged in order to expand the capacity of the power station? I am really new at this electrical stuff and I know that many on here are very experienced and knowledgeable. I had an idea and would like to know if it would work and if these are the correct parts to use.
Use an AC to DC charger and plug it in to a 110v output plug on the power station and then to the life Po4 battery.
Use a DC to AC inverter from the life Po4 battery to power things like a fridge etc …
Now the alternator charger is charging the power station to 100% in about 80 minutes. That power station charges another battery (not sure on speed though). I use the power station for some things and the extra battery for other things.
Would this setup work? How do I know how much input the life Po4 battery can handle? I would use the highest rated charger as long as I am not overdoing it.
The reason I chose a DC to AC inverter off the battery is because I don’t see any DC to DC inverters. I need to something that connects to the battery for output and then carries the power to plugs.
Am I losing or wasting any power by going from 110v from the power station then converting it to DC so it charges the battery and then converting it back to AC for the output?
Below are the items I was looking at.
12V 100Ah LiFePO4 Battery Group 31 Lithium Battery With Built-in 100A BMS, 1.28kWh Up to 15000 Deep Cycles Rechargeable Battery for RV, Marine, Solar System, Van, Trailer, Backup​
LiTime 14.6V 40A Lithium Battery Charger Mountable for 12V LiFePO4 Lithium Battery with LED Indicator and ON/Off Switch, AC-DC Smart Charger for 12.8V LiFePO4 Lithium Batteries, 40A Fast Charging​
500W Power Inverter, Car/Light Truck 12V DC to 110V AC Converter Dual 2.4A USB Ports Car Charger Inverter with Cigarette Lighter Ports for Smartphones Laptops Tablets​
Thanks,
Adam
I would recommend finding a shop that can assist you. Electrical is something you don't mess around with. If you lived in Australia, you would need an auto electrician setting it up and certified that it was done correctly.
You have a lot of things going on that aren't really all that necessary or helpful.
Stacking the Ecoflow and a separate battery seems like a really roundabout way of getting to an end goal.
Some things to consider: each time you convert from AC to DC, or DC to AC, there's a loss in efficiency. Depending on the exact equipment making this conversion, this could be up to a 20% loss in power/efficiency per step.
You mentioned going to AC to power a fridge, that's a double loss in efficiency (assuming you're using an automotive grade fridge like Dometic, ARB, National Luna, Snowmaster, Engel, Iceco, etc); as the power is going from DC to AC (to the fridge) and then internally in the fridge from AC back to DC. Even assuming the total loss is 20%, you're effectively losing that much battery capacity due to conversion losses alone.
As @ADVAW8S suggested, getting in touch with a local shop who has experience with these sorts of set ups is probably your best bet.
A tidbit that you mentioned was your choice in going with the Ecoflow because it has an 800w charger and none of the LiFePO4 setups you found could do that. The Victron Orion XS DC-DC charger outputs 700w (as does the Redarc BCDC1250A and their new BCDC Alpha), there are several DC-DC chargers that output more than that. Additionally, in the case of the Victron (and I would imagine the Redarc), they can be stacked in a parallel configuration assuming the alternator can keep up (the Victron at least can also be turned down, so you could run a pair at 40A each or whatever value you want)
I think I get your question.
Your current system sounds like a 1024wh battery and an 800w DC to DC charger.
That translates roughly to a 85ah battery and a 55A DC to DC charger.
If you want to integrate that into a car setup I would double the battery to a 150ah battery and a 50A DC to DC charger.
That is this DC to DC charger
This type of battery (which i believe fits in the battery mount location under the passenger side rear seat with the GP factor mount)
And for ac power you'd get one of these inverters. 2000W which is close to the 1800w of the Ecoflow.
I think you can fit the inverter inside the driver's side trunk sidewalls with an outlet in the wall. The rest should fit under the seat. It supports solar panels so you can charge the battery when parked.
It's a bit more money but it's built to last which I don't think the Ecoflow is. And it's roughly double the battery capacity.
Now Im no expert in this but this is the setup I'm considering.
I would add some 12v ports and maybe some powered USB ports but that's nothing in the grand scheme of things. You can get any recent overland shop outfit your car with this.
This is well proven tech in the overland community.
Good luck!
This is the info I needed!
I have a larger Delta 2 MAX arriving tomorrow. If I can get it to fit under the seat I will just swap it out for the Delta 2 since it's more simple and also sounds a tad cheaper. If it doesn't fit I will start working on a new setup and will probably be back on this thread with some more questions. I cannot stress my appreciation to the members that replied here. This was driving me crazy!
Adam
I am running AC to the fridge because the Ecoflow has just one cig lighter DC output and I run two drawer fridges. One as a fridge and one as a freezer. I go out with my 3 growing boys and let's just say they consume a lot of food ;). I got a cig lighter splitter but the Ecoflow didn't really like it. It was causing a lot of glitching. When I plus the Ac plug into the EcoFlow and the power goes through the fridges power brick which I guess converts it to DC, does that cause an inefficiency?
Thanks,
Adam
Yep, that's the double inefficiency... DC to AC to DC
You're probably overloading the fridge/freezer combo on that one circuit.
Or the power from the compressor in the fridge is dirty and ecoflow doesn't like it.
Fridges typically use a compressor. It's basically an electric motor. That type of load tends to be very noisy with electrical feedback sent back into the power line. Or maybe the Ecoflow is some weird hybrid modified sine wave that gets uglier under load. I looked for the in the manuals but they didn't call that out. I saw some scope traces which suggested the power gets ugly under load. It's why I think pure sine wave inverters are the better choice even though they cost more. Your sensitive electronics will thank me.
Good luck!
Would these items work?
Renogy 2000W Pure Sine Wave Inverter with On-Grid Transfer Switch, Built-in Bluetooth, Inverter 12V DC to 120V AC for Truck, RV, Home, 4000W Surge Power, Remote Controller​
Blue Sea Systems 7748 SafetyHub 150 Ignition Protected Fuse Block​
Renogy 12V 100Ah Lithium LiFePO4 Deep Cycle Battery, 5000+Deep Cycles,Backup Power for Trolling Motor, RV, Cabin, Marine, Off-Grid Home Energy Storage-Core Series 2 Pack
Renogy 12V 50A DC to DC Battery Charger with MPPT, On-Board Battery for Gel, AGM, Flooded and Lithium Batteries, Using Multi-Stage Charging, Solar Panel and Alternator​
Thanks,
Adam
I don't know the brand , but the products look about right.
These guys sell products for houses as well as rv's. Make sure you buy things for rv's since they have to be vibration tolerant.
I would check that battery. Make sure it's not two 50ah batteries that become 100ah together. If each is 100Ah that's good.
Personally I would aim for a single, large ( 100ah and up) battery that fits under the rear seat. Measure carefully to make sure it fits. Make sure you know how you'll mount it so you don't have a cannonball in there in case of collision. I don't think those batteries easily reuse the mounting clamps under the seat for the factory option of a second battery so you need to figure out something.
For the inverter I would check if has a fan and how noisy it is. These things can be noisy or they are of lower quality. But it looks about right.
The only thing I would add is a battery monitor unless the DC-DC charger has that built-in. I think it does but double check. You want to know when you're at 50% and 100%.
Things built for rv's generally should work well, and this looks like it's built for rv's. But you need to check.
I am just about to do the same EcoFlow Install (800w charger to Delta2) The Delta2 can take an expansion battery (either a Delta2 for an extra 1024kw, or a DeltaMax for an extra 2048kw) but it uses the same single port on the side that the 800w charger uses. I agree with the others keep it DC to DC wherever you can to minimise efficiency losses (which also equal extra heat generated)
I have two drawer fridges. I run one as a fridge and one as a freezer. I did some testing this week with just one fridge. While running it to the max at -4f it used 30% of the battery over 12 hours which really isn’t bad at all. That being said they charge so quick I can always just turn the car on if the battery is running too low. It gets to 80% charged in an hour. Worse case if I really need the extra capacity I think the easiest way to get it is to add a DC to DC charger charging a lifePo4 battery and then from the battery to the EcoFlow’s xt60i port. The xt60i port allows 15A in so with a 12.8v battery that’s 192W. Say it ends up being 150W incoming to the power station, with the fridges drawing about 100w and probably even less, that’s another 10 hours of run time. The compressors aren’t always running too. I think I can probably get right around 48 hours of run time between both batteries. Which is way way more than enough and again that’s without even having to start the car. I am always moving around anyway. The longest time the car is off is overnight which is 12 hours max. So I doubt I’ll even need to add that extra capacity.
Good luck!
Do you think the DC to DC charger is kind of like a jump start kit where it is just there, storing a battery charge so when I need it I flick it on and recharge my main battery or use it to start the engine if the main battery goes dead? Looks like it! And I guess you can just have it charge with the alternator so it is charging all the time so it is ready right?
The redarc DC to DC has that function. If your starter battery is low you can initiate a recharge of the starter battery from the second battery via the DC-DC charger. They say 15 minutes is enough to recharge the starter battery enough to get it to a level where it will start the vehicle.
It's the one feature I really like with DC to DC chargers besides that they isolate the two batteries from each other.
I don't know if all DC to DC chargers can do this so it's worth checking before committing to a purchase.
The EcoFlow charger does it as well and can also be set to act as a trickle charger. I always have Noco jump pack in the car though anyway. I think it’s important to have it just in case and also be able to help others.
Mind sharing what brand of drawers fridge/freezer you're using? Interested in a similar setup I think.....
I got two bodega drawer fridges from Amazon. The drawers are being done by Chad at drawersystems.com . They are local to me and his work is just absolutely superb. Here’s a preliminary sketch.
