Anyone found a way to switch off the infotainment screen?
alexandruast
2:12 AM
Romania
Driving at night on forest roads, even at 10% brightness, is not ideal. Is there any way to completely switch off the main display?
Press MUTE on the Volume control (as I recall).
Even on the lowest setting (0%) it's still too bright. I was thinking about a way to turn it off completely 😁
I assume it can't, at least not straightforward (unless using a piece cardboard, which is not really a bad idea after all).
Maybe a small rolled curtain integrated into a 3d printed anti-glare bracket, with a small magnet at the bottom :)
Press Mute on the volume control - switches off the main 2/3rds.
In Settings there is a Brightness control (have a look in the handbook).
What about a sheet of dark tint that you can overlay when you wish. You'd still be able to see the display if you wanted to.
