Owners manual has a statement that only the factory rack is approved as a gutter-mounted rack. Where does that leave Front Runner regarding Warranty?
This is a drawing I received from Frontrunner for a 2570mm rack they were developing for the Grenadier@Tazzieman I don't think your statement on FrontRunner is correct, FrontRunner refer you to the vehicle manufacturer for their load ratings rather than making a claim. See my Q&A with them below.
It appears they focus on engineering their platform to exceed the vehicles rating so it's not the weak point. I enclosed Front Runner's response.
After all it's the Grenadier's gutters you are attaching to.
And the Rhino rack calculations and figures are not available for the Ineos through Rhino, so you only have the roof rating figures from Ineos.
I contacted Front Runner and asked before buying the Slimline II and got the answer below:
NOTE: I have the 3/4 Slimline II rack as I have Safari roof and an Ineos released Rhino rack is not available yet (While it's coming for dual cab ute but I couldn't wait).
For the 3/4 Slimline II rack they supply 4 legs each side but the legs are slightly less wide than the rhino legs where there are only 4 for the full size rack.
If you were worried you could fit six legs in going with spacing every 2 slats, and get the same metal cross section in the channel.
I have fitted the Slimline 2 and the gutter mountings are superbly engineered. I am very impressed. And for those interested it weighs approx 43kg.
Regds Doug.
Interesting - I have seen pictures of someone with the Frontrunner full size with all three bars removed, which you can't do with the Rhino or any other North/South platforms)This is a drawing I received from Frontrunner for a 2570mm rack they were developing for the Grenadier
Their initial product was 2368 but I asked them to make it as long as possible to clear the Safari windows.
The blue line is the Safari window at full open
My thought was to slide it forward right to the edge and remove or slide back these three rungs.
That would allow you to open and remove the safari window
If you just wanted to open them you would only have to remove one rung.
This would then provide a full length rack and allow for a light bar to be mounted on the front
I'm also impressed by the FR 3/4 and I don't think I will have problems with the calculated cargo limit.@Tazzieman I don't think your statement on FrontRunner is correct, FrontRunner refer you to the vehicle manufacturer for their load ratings rather than making a claim. See my Q&A with them below.
Regds Doug.
On the FR rack the first bar is hard up against the front of the rack and shouldn't be removed as it adds rigidity.Interesting - I have seen pictures of someone with the Frontrunner full size with all three bars removed, which you can't do with the Rhino or any other North/South platforms)
I also saw that Black Sheep do a standalone front light bar for the roof that mounts off the gutter so you can leave the safari roof open and go with a 3/4 rack. Its pricey though... and theres only the gutter to nest the cable in back to the roof mount outlets. If I put a light bar on mine it will blaze through safari windows, kinda like late afternoon sun does when you are driving away from it - worse if driving into it or - kinda need blinds on the safari roof panels)
