Accessories Mounted on Rear Ladder
Someone has mounted mini Maxtraxs on the rear ladder. Pictures are posted on the forum.
The LeTech ladder posted was a great idea. But is a bit expensive for me today. But as I say: “you can justify anything if you want it bad enough!” I will try the clamp on attachment to the OEM rungs and a mount for my Rotopax for now. I may try the clamp on Hi-Lift jack mounts on the vertical rails of the ladder and will report back.
Okay, so I have installed my Rotoplex gas container on the Amazon roll bar mount on the ladder rung and it’s nice. I like that it’s solid and below the rear view vision. I have chosen to not install my hi-lift jack off the ladder vertical rails as I don’t want it to get gritted up with trial dust. I plan to mount it inside the back cargo area between the back of the rear seats and the truck vault drawer.
Anyone got a pic of the hi-lift mounted on the ladder?
I'm rethinking my hi-lift mount...
How about these
I was going to mount my jack on the outside vertical rail of the ladder and bought the mounting brackets for it but chose not to due to it fits behind my truck vault inside now. But it’s very easy to do and would be accessible.
The mounting brackets are linked in my first post above here.
I'm pretty happy with my mount of my ladder using the DVA mechanics bracket. Going up to Lake Tahoe this weekend and will be out bouncing in the mountains, i'll let you all know how it holds up.
And it was asked by someone. There are no issues with rear ultrasonics at all.
