About off-road mode swtch
Grenadian
6:12 PM
Korea
What exactly does "off-road mode swtch" do and what does it do?
What's a manual? Is that British for stick shift? Wait you can get a stick shift? I am so confused. Jk
Now you have upset my sense of well being about something that had never occurred to me.
Manual means something you do by hand... right....
How on earth can that same word mean an instruction book?
I am going away to think about that.
bot to be confused with Manuel....he's from...
Save you some time. Manual is also in on as a "how to do". Back in day they used to print instructions on how to do minor repairs
Hello?
Of course I know it's in the manual, but since English is not my native language, the short and simple user manual written in technical terms is not as easy to understand as a novel.
However, there are many people in this forum who explain in detail.
Also, when someone first joins the forum, the notice says not to answer in the way of "You can find the answer to your question by searching."
This article was written using Google Translate.
Thank you.
오프로드 모드에서는 다음이 비활성화됩니다.
자동 시동/정지(정지 시 엔진이 꺼지고 가속 페달을 밟으면 다시 켜짐)
PDC 주차 거리 제어, 범퍼가 물체 근처에 있을 때 나는 삐 소리
안전벨트 경고음
백업 카메라가 꺼진 상태로 유지됨
오프로드 모드에서는 전자식 안정 제어가 변경됩니다.
오프로드 모드에서는 하이빔 조명으로 오프로드 조명을 활성화할 수 있습니다. (미국 모델에서는 한국은 모르겠습니다.)
오프로드 모드는 44mpg 또는 70km/h보다 빠르게 주행하거나 엔진이 30초 이상 꺼져 있으면 자동으로 비활성화됩니다.
저는 또한 구글 번역을 사용했습니다. 도움이 되길 바랍니다.
Hello?
Thank you.
I'm curious, the vehicle was supplied with an English handbook? How was it supplied to you in Korea, purchased from a local dealership or imported?
Hello?
It's about 80% of the English manual.
It's similar to how the official English manual provided by Ineos is relatively lacking in content compared to the
unofficial manual (English) that can be found on this forum.
